Hi
i want to program liquid hold-up correlation inside aspen,
liquid hold-up correlation is used for liquid-gas contacting towers
i have the correlation of liquid hold-up, thats very simple correlation, but i dont know how to program it in aspen
please help me from where and how to start
Programming Liquid Holdup Of An Absorbing Tower Inside Aspen
Started by Mehdi Alizad, Jul 03 2012 07:53 AM
aspen programming liquid hold-up
Posted 03 July 2012 - 07:53 AM
Posted 05 July 2012 - 01:18 AM
From your post it is not clear what exactly you are looking for. Liquid hold up terminology is generally referred to either the column bottom sump liquid inventory or at the liquid collection trays such as chimney trays. can you further elaborate further about this term, I would be in a position to give you the procedure to model it. Waiting for your reply.
Posted 05 July 2012 - 03:55 AM
In tray columns, liquid holdup is just the liquid volume on the active area
Liquid holdup, as used within RateSep or RateFrac Module, is a volumetric liquid holdup, not a fractional holdup or holdup height.
RateSep or RateFrac allows a number of different correlations to be used to calculate holdup. Each correlation applies to certain types of columns. These correlations can be specified on the RateSep | Holdup sheet of the Tray Rating or Pack Rating form.
You can specify a liquid or vapor holdup on these sheets. If you do, the data you specify is used and the correlation is ignored
The correlations calculate liquid holdup on trays as (clear liquid height x bubbling area on the tray)
it has a simple correlation, i want to replace my correlations with aspen RateSep build-in correlations
Sulfuric Acid Plant Aspen Hysys HelpStarted by Guest_kazuki222_* , 29 Apr 2026 |
Aspen Plus Conceptual Mof Synthesis Model: Elecnrtl, Ionic Leachate, PStarted by Guest_Momo_212_* , 16 Apr 2026 |
Energy Analysis In Aspen Plus 14.2Started by Guest_Sarishma_* , 23 Mar 2026 |
Sizing Fire Case Relief Valve Installed Below Liquid LevelStarted by Guest_processrock_* , 14 Apr 2026 |
Aspen Plus Rcstr Convergence Issue – Mass Balance Error In Anaerobic DStarted by Guest_Marie26_* , 05 Apr 2026 |
