Mixing Methanol With Diesel And Use As Burner Fuel
methanol fuel; diesel; burner
#1 elpasha25
elpasha25
  • 4 posts
Posted 17 July 2012 - 12:47 AM
Dear Gentlemen:
Is it safe to mix solvent (alcohol, methanol, BTEX,.......etc) in certain proportion with diesel and use the mixture as fuel to a burner.
The solvent is either expired, recovered, or just a waste of no use! If yes, is there a rule for mixing or any restrictions on mixing?
Thank you for advice.
#2 Flame
Flame
  • 28 posts
Posted 17 July 2012 - 08:42 AM
Dear Elpasha,
I suppose you are talking about process heater / raw gas burners. Then, in this case i would suggest you take the veiws of the burner supplier.
The oil guns in the given burner are designed for a particular oil, i.e. spgr, viscosity & upstream pressure. The existing oil tip may overfire in case a lighter oil is used, leading to unsafe conditions and there is also chances of vapor locking in the oil gun (as methanol + diesel will be having a higher vapor pressure.)
Te burner OEM's are the experts & they should be consulted at the earliest.
