Dear All Friends
I need to know qatar and Saudi Arabia Experince for DSO in Merox Unit.
As you know DSO is by-product of Merox Unit.
What is existing use for DSO, is there any usefull application for it?
GB
Disulfide And Merox
Started by Ghasem.Bashiri, Jul 19 2012 02:49 PM
Posted 19 July 2012 - 02:49 PM
Posted 28 July 2012 - 03:02 PM
Most plants I have been involved with route the DSO to a naphtha hydrotreater feed drum. This needs to be controlled to a very small percentage of the NHT feed however.
Posted 29 July 2012 - 08:20 AM
DSO can be used in place of DMDS.
DSO can be blend with crude.
DSO can be blend with VGO.
Posted 02 August 2012 - 09:25 PM
I wouldn't blend DSO with crude being fed to a crude distillation unit. DSO isn't particularly stable at high temperatures and can contribute to corrosion or will increase the presence of sulfides in overhead water streams.
Posted 06 August 2012 - 12:13 PM
An alternate destination could be a Diesel Hydrotreater wherein it can be processed in admixtures with SR streams.
Disulfide Bridges Forming On A MonomerStarted by Guest_JArchy123_* , 05 Nov 2021 |
Merox Process Simulation Using UnisimStarted by Guest_Cleomari_* , 16 Aug 2018 |
H2S Corrosion In Flue Gas Stacks And Merox UnitsStarted by Guest_Ganesh Buddha_* , 08 Mar 2017 |
Caustic Draining In Merox During ShutdownStarted by Guest_Siraj_* , 30 Jan 2017 |
Caustic Free Merox ProcessStarted by Guest_Jamilll_* , 16 Oct 2015 |
