My name is Sani and I am an operations engineer working at a fertilizer complex in Pakistan. For ammonia production we are using Foster Wheeler designed primary reformer which is a "Side Fired, Terrace Wall Furnace". During start-ups we use the conventional method of firing i.e. inserting an ignition torch through the ignition doors. This technique, being old, is quite time consuming.
Is there any other technique available which we can adopt in our system to make this firing process better? Waiting for your expert opinions.
Best regards,
Sani.
Reformer Furnace Firing Techniques
Started by raza0kid, Jul 25 2012 10:49 AM
ammonia methane reforming fertilizer foster wheeler furnace primary reformer
Posted 25 July 2012 - 10:49 AM
Posted 28 July 2012 - 06:12 AM
why not think for BMS.
Posted 28 July 2012 - 06:47 AM
As recommended by Mr. Toor, a BMS (Burner Management System) is a reliable option. Installing a BMS need some extra details in your existing system, these are:
1) Fixed Ignitors at the burners. These shall be electrically operated.
2) Pilot & main flame scanners, to verify flame.
3) Block & Bleed Shut-down valve system at each individual main gas / pilot line, in order to completely automatic the burner lighting process.
4) A BMS logic in your PLC for carrying out the automatic burner lighting process.
Another option may be only installling fixed ignitors, but to be actuated only from the field, and the 'light-on' to be verified visually at site just as in the case of portable ignitors. Safe light-up procedures need to be ensured manually in this case.
Refer attachment also, it might be helpful.
Edited by Flame, 28 July 2012 - 07:03 AM.
Smr Reformer Flue Gas FlowStarted by Guest_kaidlut_* , 14 Feb 2025 |
Calculation Of Approach To Equilibrium Of Primary Reformer CatalystStarted by Guest_muthukmaar_* , 05 Jul 2019 |
Ch4 Reformer Firing Control SchemeStarted by Guest_Divid Kelin_* , 11 Jan 2023 |
Hydrogen Fired Steam Cracking FurnaceStarted by Guest_panoska_* , 17 May 2022 |
Steam Methane Reformer In Production Of Methanol From Natural GasStarted by Guest_adam123collings_* , 01 Mar 2022 |
