Can anyone please tell what is the pressure range while doing mechanical cleaning (high pressure water cleaning) for plate heat exchangers.
Cleaning Of Heat Exchangers
Started by ayche, Aug 02 2012 01:21 PM
Posted 02 August 2012 - 01:21 PM
Posted 02 August 2012 - 07:25 PM
It depends what is the material on the plate and the efficiency of the nozzles . I would say below 50 bars.
Pay attention to the gaskets or you may consider to replace all of them.
Hope this helps
Hope this helps
Posted 03 August 2012 - 12:34 AM
Thnks a lot for this informationr Sir.
and Sir does the range remains the same (or around it) for welded plate heat exchangers such as bloc type,plate and shell type etc.
Posted 03 August 2012 - 12:42 AM
I've no experience for welded equipment , I'm thinking that CIP is a better way to clean them
Best Heat Exchanger Type For Gas HeatingStarted by Guest_Gole_* , 29 Jan 2024 |
Heat Of Dilution Of Hydrogen Chloride In Hydrochloric Acid Solution (3Started by Guest_fredlan54_* , 21 Nov 2025 |
Shell And Tube Heat Exchanger In HtriStarted by Guest_Sanjayr126_* , 28 Sep 2021 |
