At the bottom of the column, the liquid is near its saturation condition. To recovery the waste heat from the stripped water, the stripped water will exchange heat with the feed. Due to pressure loss and elevation change, the stripped water may flush in the first heat exchanger the stripped water in. To avoid the water flushing, the normal way is to raise the column to get enough liquid head for the heat exchanger. In our case, the skirt height is 22 ft, the column is 72 ft and the total height of the column is 94 ft.
By raising the column to a higher level, the foundation and structure costs will increase significantly.
My questions are:
1, What is the consequence if the water flushes at the shell side of the exchanger? Will this cause a condensed-steam induced water hammer inside the heat exchanger because eventually the flushed steam will be condensed by the cold feed?
2, Will this flushing steam significant affect heat exchanger heat transfer or not?
3, Is there other way to not raise the column at same time to avoid water flushing?
I appreciate your thoughts
