Edited by premjagan, 01 September 2012 - 03:24 PM.
Boiler Drum Steam Header
Started by premjagan, Sep 01 2012 03:23 PM
Posted 01 September 2012 - 03:23 PM
why boiler drum steam header exit line having mostly ON/OFF valve or motor operating valve rather than control valve? any specific reason is there?
Posted 12 October 2012 - 03:01 PM
Yes,
At least in the US, code requires that boilers have block valves for steam isolation purposes. Control valves are notorious for leaking by, especially with superheated steam..
Posted 13 October 2012 - 05:03 AM
Go through ASME Boiler & Pressure Vessel Code Section 1
B31.1-122.1.7(A),(A1),(A1A)
Converting Superheated Steam To Saturated SteamStarted by Guest_addiesalsabil_* , 10 Sep 2023 |
![]() Steam Used In ReboilersStarted by Guest_aliebrahem17_* , 05 Jul 2025 |
Steam On Shell Side Of A Vertical HexStarted by Guest_Lyne_* , 09 Jul 2025 |
