I am a chemical engineering student doing research on plate and frame and other types of plate heat exchangers for last few months.I had a query in mind that is.for the same process conditions how much lesser area(by what percent) will serve the purpose if we use a plate heat exchanger in place of shell and tube.?
Comparison Between Shell And Tube And Plate Heat Exchangers
Started by ayche, Sep 10 2012 05:28 AM
No replies to this topic
Posted 10 September 2012 - 05:28 AM
Heat Exchanger Temperature CrossStarted by Guest_kaidlut_* , 20 Dec 2022 |
How To Estimate The Water Dewpoint From Heat And Mass Balance Of NaturStarted by Guest_krishnnaa26_* , 30 Apr 2026 |
Waste Heat BoilerStarted by Guest_Prim_* , 25 Apr 2026 |
