This is Mahendar Errala from India.
I have to design a batch distillation column for dehydrating N-Methyl piperazine which is having 4.0% moisture.
I am not getting VLE data for N-Methyl piperazine+Water mixture at 100mmHg absolute pressure from the literature or internet.
Could somebody help me in finding Antoine coefficients and vapor pressure for N-Methyl piperazine.
I hope that someone will help me.
Thanks in advance.
N-Methyl Piperazine Antoine Constants
Started by Mahendar Errala, Sep 12 2012 04:35 AM
n-methyl piperazine antoine c
Posted 12 September 2012 - 04:35 AM
Posted 14 September 2012 - 08:07 PM
If you shall not get data;please check with small glass pilot plant to generate data like height require to have desired purity.This may be done in your R and D lab.
Posted 15 September 2012 - 07:38 PM
Here are the coefficients as found in Yaws, Carl L; Narasimhan, Prasad, K.; Gabbula, Chaitanya, Yaws' Handbook of Antoine Coefficients for Vapor Pressure (2nd Electronic Edition), Knovel.
1-Methyl Piperazine, CAS 109-01-3
A = 7.62185
B = 1686.39
C = 217.7
Tmin = 3.56 C
Tmax = 189.2 C
The correlation for vapor pressure as a function of temperature is based on the Antoine equation:
Log10 P = A – B/(T + C)
where
P = vapor pressure, mm Hg
A, B and C = Antoine coefficients for compound
T = temperature (centigrade), C The tabulated values are based on regression of experimental data and researched estimates.
Tmin and Tmax describe the temperature range for which the equation is valid.
A = 7.62185
B = 1686.39
C = 217.7
Tmin = 3.56 C
Tmax = 189.2 C
where
Posted 20 September 2012 - 02:27 AM
Thankyou Mr.Steve Hall.
The data provided by you is very much usefull for me.
Mahendar Errala
Mahendar Errala
Posted 20 September 2012 - 02:36 AM
Dear members,
I also in searching of data regarding 1-Methyl Piperazine(CAS 109-01-3) thermodynamic Properties at 100mmHg absolute pressure such as density, Latent heat of vaporisation, Specific heat & Viscosity.
Thanks in advance.
Thanks in advance.
Posted 22 September 2012 - 10:46 AM
Really Helpful and good information.If Antoine constants for 1-Methyl Piperazine is available,For any such large molecule,we have to gcheck this reference.
Antoine Equation QuestionStarted by Guest_panoska_* , 10 Feb 2023 |
Looking For Enthalpy (H) – Entropy (S) Chart For Chloromethane (MethylStarted by Guest_fredlan54_* , 18 Jul 2022 |
Phenol Removal From Solvent (Methyl Isobutyl Ketone) In Aspen HysysStarted by Guest_HzO_* , 28 May 2021 |
Kinetics Data For Methyl Methacrylate SynthesisStarted by Guest_HappyFeet_* , 27 Jan 2021 |
Methyl Chloride Abatement TechnologyStarted by Guest_TheChemEng_* , 26 Aug 2020 |
