could anyone tell me what is the proper installation of an oriffice( according to the flow direction)?
What will take place if the oriffice was installed in the wrong direction?
Thanks in advance
Manhal
m71mouly@yahoo.com
Restriction Oriffice
Started by Manhal, Jan 04 2006 02:36 PM
Posted 04 January 2006 - 02:36 PM
Posted 04 January 2006 - 05:41 PM
Manhal,
I'm not sure that I understand your question, but I'll respond to what I think you're asking.
There is an upstream and a downstream side to all orifice plates. The sharp edge of the orifice should face upstream, while the bevelled edge faces downstream. If you install the orifice plate reversed, the pressure drop will be less than what you expect and/or the flowrate will be greater than what you expect. That is because you will have introduced a more gradual approach to the minimum opening, sort of a converging section. Granted the convergence occurs over just the thickness of the orifice plate, but I believe the effect is significant nonetheless.
Doug
Doug
Posted 05 January 2006 - 09:50 AM
I would like to thank you DOUG , that is exactly the answer I wanted to ensure
Manhal
Manhal
![]() Restriction Orifice And Correct Location Of Class BreakStarted by Guest_F.Sh_* , 06 Aug 2025 |
![]() Manual Depressurisation - How To Determine Restriction Orifice SizeStarted by Guest_FUNMILAYO_* , 14 Oct 2020 |
![]() Coefficient Of Discharge For Restriction OrificeStarted by Guest_Estiqaatsi_* , 04 May 2023 |
Restriction Orifice In Close Drain System For An Gas FilterStarted by Guest_Sam rock_* , 08 Mar 2022 |
![]() Restriction Orifice Design And SelectionStarted by Guest_nsr.kn85@gmail.com_* , 03 Nov 2020 |
