I am currently working with gas dehydration unit. I’ve made a model of gas-TEG contactor. I use PR package.
At 10 C and 450 psig water content for gas feed will be next:
Hysys – 20,86 lb/MMSCF
GPSA – 22 lb/MMSCF
To meet water dew point (-8 C at 3.92 MPa) I need to remove total 4,5 kg of water per hour. According to GPSA reference recommended TEG flow is 1,5 gal TEG/lb HO2 removed. So minimum required TEG mass flow is 1,5 x 8,34 l/kg = 12,51 l TEG / kg H2O removed. Total = 12,51 x 4,5 =56,29 liters of TEG per hour. It is about 63 kg of TEG.
Hysys calculated TEG mass flow rate – 15,8 kg/hour required to meet it specification. With Glycol package
Hysys calculated TEG mass flow - 10 kg/hour.
GPSA - 63 kgTEG/hour
Hysys (PR) - 15,81 kgTEG/hour
Hysysy (Glycol package) - 10 kgTEG/hour
Question - It is very low TEG flow rate in both cases (PR and Glycol package) if compare with thumb rule or GPSA reference. Does Hysys calculates wrong TEG flow?
Many thanks
