Distillation Column Design For Ethanol Water Mixture
Started by Pink_Rose, Oct 02 2012 08:28 PM
Posted 02 October 2012 - 08:28 PM
How to Design a Distillation Column for Ethanol Water Mixture, 95% recovery in Distillate, which is around 110-120 L/day? Help!
Posted 02 October 2012 - 11:03 PM
Hi Pink-Rose .
What do you know about distillation ? Do you know Mac cabe & Thiele ? data are missing like feed composition and purity
I've attached a resource that can help you .
http://www.chemsof.com/vle/vle.htm
Edited by breizh, 02 October 2012 - 11:37 PM.
Posted 03 October 2012 - 05:04 AM
Hello Pink Rose,
I've had a similar project assigned to me, in order to comprehend some of the basics of distillation I've made an Excel file which applies the Fenske, Underwood, & Gilland (FUG) Method to calculate some things. It's not completed yet since a part of the batch distillation calculations are not done yet, but perhaps it is of interest to you aswell.
Batch destillatie opzet.xlsm 92.71KB
422 downloads
Edit: it does not consider azeotropes but should give you a general insight into distillation calculations.
Edited by Wit Knien, 03 October 2012 - 05:05 AM.
Posted 14 October 2012 - 01:48 PM
You first study Distillation design by Henry Z.kister or Ludwigs chemcial engg vol 2..
I am sending you a distillation column design sample, it will also help you in designing your column.
Posted 15 October 2012 - 06:20 AM
Ethanol & Water will form an AZEOTROPE so, you have to add a solvent Toluene for this.
During my graduation final semester seminar & project was on AZEOTROPIC DISTILLATION.
Posted 15 October 2012 - 06:22 AM
There are other possibilities, consider mol sieve / ceramic membranes.
![]() Wet Scrubber Design For Low Flow Rate Of GasStarted by Guest_SIVAMOORTHY_* , 17 Apr 2018 |
Rupture Disk Tail/lateral Piping Design BasisStarted by Guest_Karthikram_* , 19 Aug 2025 |
Hybrid Packed And Tray ColumnStarted by Guest_Zulfise_* , 04 Aug 2025 |
Pem Water ElectrolysisStarted by Guest_tomr91_* , 29 Jul 2025 |
![]() ![]() Design Of Direct Contact After Cooler (Dcac) For Air Separation UnitStarted by Guest_Paulogeorge_* , 29 Jul 2025 |
