i am just new in my company ion coal power plant...just wanna ask some of your brilliant ideas on how will my issue solve.
i do have hard time to maintain the pH of the drum within 9.2 - 9.6 pH.If i do increase the phosphate doing on it still there is quite low increase of pH but has high increase of specific conductivity that results high phosphate concentration...do u have an idea on how will i change my my dosing of phosphate that will give within the range of pH.thank you
Ph Vs. Phosphate Dosing
Started by Guest_krampal29_*, Oct 12 2012 05:54 AM
Guest_krampal29_*
Posted 12 October 2012 - 05:54 AM
Posted 18 October 2012 - 08:06 AM
I would try replacing phosphate being used with another, of higher content in disodium phosphate / trisodium phosphate. This would shift pH to more alkaline regions, in comparison to monosodium phosphate. See attached pdf file, Recommendation 4.
Estimating pH in aqueous solutions (25 oC) of NaH2PO4, Na2HPO4, Na3PO4 using ionic equilibrium principles is not easy ( http://en.wikipedia.org/wiki/Acid_dissociation_constant). But we can qualitatively say that pH will increase with increase of PO43- (or even of HPO42-) anions and corresponding decrease of H2PO4- anions (total molar concentration same). H3PO4 is a rather weak acid (indicated by its dissociation constants).
Edited by kkala, 18 October 2012 - 08:12 AM.
Burning Or Explosion Of Calcium Phosphate Inside Water - Possible CausStarted by Guest_Geetanjali_* , 17 Nov 2023 |
Dosing RateStarted by Guest_Dorota86_* , 10 Oct 2022 |
Chemical Injection Stinger For Chemical DosingStarted by Guest_CHEMSTRONG_* , 08 Aug 2022 |
Chemical Injection Pumps For DosingStarted by Guest_CHEMSTRONG_* , 07 Aug 2022 |
Chemical Dosing For Cooling TowerStarted by Guest_R_Gowtham_* , 23 May 2022 |
