Theoretical Trays Per Fenske & Mccabe-Thiele
11 replies to this topic
#1 trungphu
trungphu
  • 106 posts
Posted 14 October 2012 - 01:00 AM
I have calculated the number of theoretical stages for a distillation column that fractionate 3000kg/h of an acetone-benzene solution containing 0.3656 mole fraction acetone at bubble point by two methods: McCable-Thiele diagram and Fenske equation. It is desired to produce a distillate containing 0.9851 mole fraction acetone and a residue containing 0.006713 mole fraction acetone. I was wondering whether this two methods always give nearly the same result or not. In my case, I get a major different result from those methods. For the same reflux ratio of 3.518, I got 26 theoretical stages from McCable-Thiele diagram and 18 theoretical stages from Fenske equation. Attached is my McCable-Thiele diagram.
I believe something was wrong here. Could someone give me some advances?
TrungPhu
  • 6,801 posts
Posted 14 October 2012 - 06:28 AM
Trung Phu
Let you consider this resource to validate your work ( mac cabe &thiele) :
http://www.chemsof.com/vle/vle.htm
Hope this helps
#3 trungphu
trungphu
  • 106 posts
Posted 25 October 2012 - 04:35 AM
I really appreciate your help, Mr.Breizh
#4 USR
USR
  • 66 posts
Posted 26 October 2012 - 03:07 AM
I remember using Fenske equation for calculating minimum number of stages hence it you are getting the minimum number of stages that is 18.Though I have not checked your calculations.
#5 S.AHMAD
S.AHMAD
  • 786 posts
Posted 01 November 2012 - 01:51 AM
A quick check using PRO-2 simulation I got 24 theoretical trays inclusive reboiler and condenser with feed on tray 11 from top. Distillation at 15 psia.
Edited by S.AHMAD, 01 November 2012 - 01:52 AM.
#6 trungphu
trungphu
  • 106 posts
Posted 02 November 2012 - 12:33 PM
Dear Mr S.AHMAD,
Thank you so much for your help! Could you tell me which thermodynamic data you have chose for your simulation. Actually , I got the result that different from yours by using PRO-2.
Edited by trungphu, 02 November 2012 - 09:25 PM.
#7 S.AHMAD
S.AHMAD
  • 786 posts
Posted 06 November 2012 - 03:29 AM
I am using Peng-Robinson
#8 trungphu
trungphu
  • 106 posts
Posted 07 November 2012 - 01:49 AM
thank you kindly. I will check it again.
#9 Dacs
Dacs
  • 457 posts
Posted 07 November 2012 - 03:02 AM
While I won't try to comment on your particular problem (i.e., how you came up with the numbers), I think Fenske method will only give you the minimum theoretical trays to meet the needed separation at total reflux (i.e., without any distillate and bottoms being drawn from the column)
I don't think they're comparable at all.
#10 trungphu
trungphu
  • 106 posts
Posted 07 November 2012 - 03:46 AM
Dacs
You are right. Actually, in this case, I mean the Fenske - Underwood - Gilliland (FUG) method, not Fenske method. I'm sorry for my mistake here.
FUG method consist of three main parts and can allow us determine the theoretical stages necessary to produce desires product.
So we can make a comparison for this two methods, McCable-Thiele and FUG.
Edited by trungphu, 07 November 2012 - 05:20 AM.
#11 Dacs
Dacs
  • 457 posts
Posted 07 November 2012 - 07:30 PM
Truth be told, it's been ages since I even touched a McCabe-Thiele diagram.
But from what I can tell, there are some underlying assumptions behind those methods. IIRC, there should be a constant molal overflow (or something) that has to be assumed for McCabe-Thiele method.
Maybe you can look into those basis and compare it with your system and see how it holds up.
#12 Ahsan67
Ahsan67
  • 40 posts
Posted 09 November 2012 - 04:57 PM
kindly check what relative volatility you used in your solution while using fenske equation , average or you calculated by correlation ??
because if there is a big difference between top & bottom relative volatility we can not use average relative volatility in fenske equation,be careful, use underwood's equation for minimum reflux and then Erbar-Maddox(stages Vs Reflux) correlation can be use for finding theoritical number of plates, fenske equation is used for finding minimum number of plates becase it assumed 100% reflux situation which will occur at 45 degree in McCabe-Thiele digram
