Hi
I require to calculate the outage and innage volumen to determine the gross capability of a spherical tank. This tank will store Propylene at 38ºC but then is cooled to 5ºC. The net capacity is 3000 m3 . Can any one advice me how to estimate these volumes.
Thanks in advance
Outage And Innage Volume Calculation
Started by digeca, Oct 25 2012 08:07 AM
Posted 25 October 2012 - 08:07 AM
Posted 25 October 2012 - 09:51 AM
I would appreciate knowing the definition of "outage" and "innage" in your query. Is your tank perfectly spherical? What are its dimensions?
Posted 26 October 2012 - 04:19 AM
Outage: Thermal expansion volume of the liquid.
Innage: Remaining volume of the sphere at the bottom below the higher end of the suction line of the pump. (inside the sphere).
Yes, our tank is perfectly spherical.
The project is in conceptual fase and we don´t have the dimensions yet. The idea is to get real dimensions once the outage and innage volume is obtained. For the net capacity (3000 m3) the tank dimensions could be 22.55 m of diameter, but we need to add the volumes listed above.
Surface Area Calculation For Blowdown Orifice Sizing Including FinnedStarted by Guest_victortheone_* , 17 Feb 2026 |
Horizontal Decanter Sizing CalculationStarted by Guest_peejoee_* , 07 Oct 2025 |
Nozzle Sizing CalculationStarted by Guest_BabRafiq1_* , 26 Aug 2022 |
Dew Point CalculationStarted by Guest_Aditya000333_* , 17 Sep 2025 |
