Hi
I wish to design a double pipe (heat jacketed) heat exchanger by using HTRI.
Input and output temperatures of annulus and pipe are known.
Tube side flow rate is known too.
The pressure of tube is around 150 bar and the pressure of annulus fluid is 10 bar and both in the liquid phase.
Three design parameter (Jacket diameter, Pipe diameter and pipe length were set).When I tried to design a jacketed pipe heat exchanger (as above specification) the result were shown as steps. I surprised when I saw that the overdesign factor was around 70-100% with the minus sign.
Please tell me what it means.
If anyone has as a tutorial on Jacketed pipe heat exchangers, It's be good for me.
Thanks.
Design Of Double-Pipe Heat Exchanger
Started by freeman, Nov 22 2012 05:20 AM
double pipe jacketed pipe hairpin
Posted 22 November 2012 - 05:20 AM
Posted 12 December 2012 - 01:35 AM
The answer is within your post, i.e. three parameters mentioned above, Jacket pipe diam, inner pipe diam and length. Addition to these parameters vary number of units in parallel if pressure drop is a limitation. I hope now you can design the exchanger.
Absorber And Stripper Design - Eqbm Data?Started by Guest_ChemEngBoy26_* , 03 May 2026 |
How To Estimate The Water Dewpoint From Heat And Mass Balance Of NaturStarted by Guest_krishnnaa26_* , 30 Apr 2026 |
Waste Heat BoilerStarted by Guest_Prim_* , 25 Apr 2026 |
Adsorber Design Essay QuestionsStarted by Guest_Kahirn_* , 10 May 2019 |
Scrubber DesignStarted by Guest_syamsundar_menon_* , 02 Jul 2018 |
