I am about to do my master`s defence in CO2 removal process using a mixture of amines.
I used Unisim R400 to model the process and I also used DBR amine package to study the effect of Piperazine into the removal process.
A part of my thesis care of the effect of amine circulation rate Vs. CO2 in treated gas while making alllll other parameters constant. I expected for CO2 in treated gas to decrease while increasing the circulation rate till reaching the equilibrium. but I found the following
Uploaded with ImageShack.us
I monitored the results for 4 different temperatures for the lean solution. Every one of them have a deviation as the CO2 in treated gas increases suddenly and then back to decrease as its normal performance. I do not have a good interpretation for this deviation.
I just suspect of transition from laminar to turbelent flow which decrease absorption efficiency then increase it especially with a mass transfer limited reaction such as this one....
Kindly help
 Forums
   Forums Blogs
   Blogs Articles
   Articles File Library
   File Library FAQ
   FAQ Search
   Search FB
