There is a need to heat 1 t/h of 12 bar steam from 200 deg C to 400 deg C in one of our units.
Since the requirement is temporary (for a short period of time), I am looking for "out-of-the-box" solutions.
I came across a website, www.thermalhire.com, which specialises in providing ceramic pads, typically used for post weld heat treatment.
Can I wrap these pads on a pipe and simulate a heat exchanger ?
1. Will this work ?
2. Typically electric heat tracing cannot deliver more than 50W/m. How is this different from an electric heat tracing ?
3. How do I calculate required pipe length ?
Ceramic Pad Heaters
Started by , Jan 13 2013 06:59 AM
No replies to this topic
Posted 13 January 2013 - 06:59 AM
![]() Fired Heaters/ Burners/ Flue VelocityStarted by Guest_Lyne_* , 15 Mar 2024 |
Troubleshooting Temperature Overshooting In Convection HeatersStarted by Guest_Alaa55_* , 27 Oct 2024 |
Electric HeatersStarted by Guest_panoska_* , 24 Sep 2022 |
Api Vs Non-Api HeatersStarted by Guest_Sherif Morsi_* , 29 Sep 2022 |
