thanks
Isoamyl Alcohol
Started by Guest_fatocar_*, Feb 05 2006 12:23 PM
Guest_fatocar_*
Posted 05 February 2006 - 12:23 PM
thanks
Posted 06 February 2006 - 03:30 AM
Hi
I really don't kind so that anyone wouldl be able to teach you the whole process on the internet. Only thing we can do is to provide you the references from where you can get your required information. So try to find your required process in the following books
1 ) McKetta, J.J, ”Encyclopedia of Chemical Processing and Design”
2 ) Encylopedia of Chemical Engineering by Kirk Othmer
3 ) Shreves "Chemical Process Industries Handbook"
Check out these books and read the processes given there. If then you feel some problem in understanding the process return to the forum and ask questions about that. So that the Engineers having experience in this process can help in yours problems.
I hope this helps.
Ali
I hope this helps.
Ali
Maleaic Anhydride And Isopropyl AlcoholStarted by Guest_Gautam Datta_* , 29 Mar 2021 |
Isopropyl Alcohol Recovery From Process GasStarted by Guest_SIVAMOORTHY_* , 10 Mar 2018 |
Alcohol Added To Gasoline FuelStarted by Guest_engeng_* , 02 Nov 2017 |
Boutique Distillery Alcohol QuestionStarted by Guest_distillerdave_* , 23 Sep 2015 |
Differential Equation For Alcohol Evaporation Under Adjustable PressurStarted by Guest_Cossack_* , 31 May 2014 |
