We have been designing a glycol reboiler for a 20 MMSCFD dehydration plant.
1. According to different vendor table like Sivall's the reboiler duty is much higher then what we calculate from different literature.(see bellow)
2. We used heat flux of 6000 Btu/ft sq to find the area of fire tube. If we calculate length and diameter according to Sivall's duty we had to use higher heat flux.
so if we use circulation rate 110 gal/hr then reboiler heat duty form sivalls table is 0.175MMBTU/hr. But size of the reboiler does not match. Size is much greater in Sivalls then other reference.
Now
According to API 12 GDU The heat duty is 0.1342 MMBTU/ hr
According to Gas Dehydration Field Manual (Arnold) is 0.1 MMBTU/hr
According to GPSA 0.11 MMBTU/hr
But the thing is that according to Sivall's table,
it is about 0.175MMBTU/hr according to our glycol flow rate of 110 Gallon /hr
For glycol circulation rate calculation we used 3 gal/lb of water removed.
According to HYSYS inlet gas to contactor tower contains 42 lb/hr of water means 50.8 lb/MMSCF. outlet gas contains 7 lb/MMSCF
We are concerned that the reboiler will be able to perform the operation. means will it be possible to raise the glycol temperature to 396 deg F.
I have attached a snapshot of my HYSYS file so that temperature of different straems can be known.
Untitled 71.jpg 46.09KB
44 downloads
I will very much appreciate any suggestion.
Processengbd
