I was going through API Std 2000 and EN14015 on Self-Supporting Cone Roof. In API Std.2000, the following rules shall be met:
a) theta <=37degrees (slope 9:12)
theta >= 9.5 degrees (slope 2:12)
To calculate theta, two formulas are provided that are:
Min. thickness = [Nominal diameter of tank shell (m) / 4.8 sin(theta)] >= 5mm
Max. thickness = 12.5mm
theta is defined as angle of the cone elements to the horizontal in degrees.
In EN14015, for Self-Supporting Roof, the slope provided is 1:5 (unless otherwise specified).
Which one should I follow?
The second part is assuming I have a FRT of 73.0m in diameter. If I were to calculate theta with the assumption that the thickness is 5mm, the formula shall look like:
73.0m / 4.8 sin(theta) = 5mm
sin(theta) = 3.042
(theta) = arcsine (3.042)
Obviously, I am unable to calculate theta as the range is between -pi/2 to pi/2. Is my calculation wrong?
Appreciate your advice on this matter.
Victor
