Alternatives To Steam For Heating
Posted 04 April 2013 - 05:53 AM
Posted 04 April 2013 - 07:11 AM
Buy a back-up boiler.
Posted 04 April 2013 - 12:03 PM
Shpereira:
I don’t understand what you mean by “a super critical CO2 plant” or the importance of having 55 oC water constantly available. But I think I can guess: you produce a stream of supercritical CO2 for either transport purposes or for processing the oils or other ingredients from a mixture by selectively dissolving them in the SC CO2. Either way, you must ensure that the CO2 is kept in the SC state and for that you need a constant heat source. You normally use saturated steam to heat the CO2 and are looking for an alternate method.
What I would do is identify the RATE of heat transfer that you need. You haven’t told us that and it is the measure that is of most importance. To find that out, multiply the flow rate of CO2 that you have above the critical pressure (approx. 980 psia) by the enthalpy difference of it at that state and the heated state that you need to ensure that it is supercritical. This heat load capacity will indicate to you the relative size of the method you need to heat up the flowing stream. If if is relatively low, you might be able to justify an electric immersion heater – such as a Chromalox type.
If you don’t know how to do the calculations, tell us:
- The flow rate of your CO2 stream;
- The cold state of your CO2 (the pressure and temperature);
- The desired heated state of your CO2 (the pressure and temperature).
Posted 04 April 2013 - 11:39 PM
Is it a chemical cleaning?, what type of cleaning your boiler required(twice a week) , is that type of cleaning cant be be operate online??? (Online cleaning- You can clean your boiler parts online while running with out shutdown).
Edited by ramsingh_mech, 05 April 2013 - 12:15 AM.
Heating Of Natural GasStarted by Guest_kaidlut_* , 01 May 2024 |
Flash Steam Vessel SizingStarted by Guest_JohnFields343_* , 24 Apr 2024 |
Steam AccumulatorStarted by Guest_Valeriacortez11_* , 15 Apr 2024 |
Answered
Steam Pressure Requirements For Limpet Batch ReactorStarted by Guest_golegolegole_* , 10 Apr 2024 |
