Dear All
Good day!
Please do share the mechanical stopper proposed by the vendor. This would be a good learning for all of us
I do agree that my knowledge is limited to mechanical stoppers installed on Fisher, Masonelian, Flowserve, GE, Dresser Becker valves, Euro valves etc and just to share with you that the mechanical stoppers are not very different for all these type of valves and are either limiting the torque or lift and you remove it, or readjust it in your ordinary workshop very easily
Had your safety system not limiting, I would simply comment to just install it.
I would suggest to please do consider 02 small valves ( 50 % capacity or one big one small ) in split range to limit CV to desired level so that your safety system should not be jeopardized in any case.
I personally do not agree that updating operating instructions or manual will help as this would not eliminate the actual risk due to human error unless otherwise the severity is mitigated some other means which probably you are the best judge as we are not fully aware of your process
Hope you may understand
Best regards and God Bless you
