Hello all. I have customers asking if they can use Nitrogen instead of Heluim in a compressed gas emergency inflation system due to availability and cost. The Helium is currently compressed to ~4200 psig (290 Bar) at 21 degrees C in the system reservior. The question I need to answer is do they need a larger reservior and/or a higher pressure rated reservior to have the same inflation volume of gas when the system is activated. The pressure in the system bladders after activiation is ~2.5 psig (1.19 Bar) at 21 degrees c.
I have used Ankur's spreadsheet for calculating the z factor for these two gases. I find little difference in the z factor values when I include the quantum gas correction factors in Tc and Pc for Helium. I would have expected a significant difference (10-20%) in the required pre-activiation volume/pressure given the differences in the gas properties. My calculations currently yielding about a 1% difference. Is this a reasonable assumption?
Thank you for any feedback on this topic.
