Pigging Run Time Calculation In Oil Line
#1 sundart
sundart
Posted 25 May 2013 - 12:51 PM
Oil line from one to other end  ,how to calculate for liqiud and gas. pigging run time, I know flow rate and dia of pipe and distance , which type of formula or equation to be used. by manual method.pl reply
can any one check this equation
Pig run time in Minutes = (D/2 * D/2) *3.14*12*7.48*L
                                             1728 * Q
L= length in feet
Q=flow in GPM
D= Dia of pipe in inch.
Edited by sundart, 29 May 2013 - 07:53 AM.
  • 6,898 posts
Posted 25 May 2013 - 06:42 PM   Best Answer
Consider these resources to support your query .
 t # V/Q with t :time, V volume of the pipe and Q the flow rate of fluid applied !
#3 Shivshankar
Shivshankar
  • 257 posts
Posted 26 May 2013 - 05:08 AM
Sundart,
Hope this helps you.
http://www.cheresour...peline-pigging/
Once you find velocity parameter,  you can find time.
Shivshankar
Edited by Shivshankar, 26 May 2013 - 05:17 AM.
