Can anyone tell me what is the best way to figure out how long it would take to pressure up a 12" pipeline 52,000 feet from atmospheric to 300 psig using nitrogen at a rate of 1MMCF/Day?
Posted 28 May 2013 - 09:10 PM
Posted 28 May 2013 - 10:31 PM Best Answer
Calculate the mass of nitrogen at 300 psig that is contained in the pipeline volume. Divide that by the mass rate of 1 MMSCFD. The time is then the time units of the input flow. If you need to get the density at 300 psig and/or standard conditions, go to www.checalc.com.
Design Compressor For 35% H2S & 1.05Ksca Suction PressureStarted by Guest_GanjiS_* , 29 Apr 2024 |
Answered
Steam Pressure Requirements For Limpet Batch ReactorStarted by Guest_golegolegole_* , 10 Apr 2024 |
Ammonium Sulfate Process SimulationStarted by Guest_amir55261_* , 06 Apr 2024 |
Pressure Control Valve Issues For Gsw LinesStarted by Guest_fahadazh_* , 29 Mar 2024 |
