I want to remove this post.
Edited by jatinder, 17 June 2013 - 09:30 AM.
Posted 13 June 2013 - 10:06 AM
Posted 14 June 2013 - 02:49 AM
In your Word document, for a gradual contraction the way you have defined ξ is exactly the same as the way Crane have defined K in equation 2-15. You then calculated K as K = ξ - β4 + 1 and K = ξ + 1/ β4 - 1. Is this intended to be a correction factor for laminar flow? You have not detailed what your Reference 25 is.
Note that although the Crane 410 document states in a few places that the K values are valid for laminar as well as turbulent flow, the K values are in fact valid for fully developed turbulent flow only. You are correct to therefore apply a correction factor if you are working with laminar flow, but you have not explained where the correction factor comes from.
Automation Of Spreadsheet Exported Variable (Hysys-Vba)Started by Guest_Thegeceb_* , 28 Jun 2022 |
Hydraulic Resistance Of Tees Converging Vs. Diverging Flow Crane Tp 41Started by Guest_PhilippM_* , 14 Mar 2020 |
Nelson Complexity Index(Nci) SpreadsheetStarted by Guest_Takechi_* , 12 Dec 2019 |
Looking For A Spreadsheet To Calculate Flow Rate Through Control ValveStarted by Guest_sheiko_* , 14 Oct 2019 |
