i have i project :
i have demethanizer column with 2 fixed diameters (trayed column 15 tray, 10 upper section and 5 lower section ) i must change the internals with packing, and calculate the capacity how much it increased ??
Note: i can't change the shell only the internals of the column ( trays with packed )
are there equation for hand claculation ?? to estimate maximum capacity for packed column ?
thanks alot
Packed Column Capacity Calculation
Started by Guest_rashh_*, Feb 27 2006 05:15 PM
Guest_rashh_*
Posted 27 February 2006 - 05:15 PM
Posted 01 March 2006 - 01:20 AM
I believe there is some usefull stuff in Perry's ch13-15
Guest_Rashid_*
Posted 09 March 2006 - 03:12 AM
i think there is no thing related to the topic in Perry's ch13-15
thanks for replay
thanks for replay
Posted 14 March 2006 - 08:47 AM
It's simple and useful to use a F factor; the F factor is more or less the square root of a kinetic energy
F = U * sqrt(rhov) where U is the vapor velocity (m/s) and rhov the mass density (kilogram/m3) of the vapor.
The packings, depending on their intrisic capacity have maximum F factors between 1 and 4 m/s sqrt(kg/m3)
Knowing your vapor rate, the shell diameter and the packing type, this will immediatly tell you whether this packing is OK or not.
For tray replacement, a first approach with a structured packing like the 250Y (Sulzer) is not bad. Sulzer has a software, free to download, that calculates the capacity, but it's easily done by pencil & paper. For 250Y maximum F is about 2.5 at atmospheric pressure.
As a second step, then you will take into account the liquid rate, using capacity curves.
You may want to look at the Perry's handbook, or Kister's books (distillation operation or distillation design)
Guest_Rashid_*
Posted 16 March 2006 - 07:36 AM
could you tell the equations taht can i do the hand calculation for that capacity ??
Ethylene Glycol Purification ColumnStarted by Guest_sg21255_* , 19 May 2026 |
Conceptual Sizing Of Adsorber ColumnStarted by Guest_JJvdM_* , 24 Oct 2019 |
Surface Area Calculation For Blowdown Orifice Sizing Including FinnedStarted by Guest_victortheone_* , 17 Feb 2026 |
Horizontal Decanter Sizing CalculationStarted by Guest_peejoee_* , 07 Oct 2025 |
