Hiii all,
Please let me help on to find the line size's for PSV . PSV is conventional type and sized at
The maxium flow capacity is 227.67 kg/hr of natural gas ,
set pressure 6.0kg/cm2 g
operating pressure 2.5 kg/cm2g
Allowable over pressure is 21%
operating temp 57 deg C
releiving temp 501.78 deg C
max operating pressure is 90% of set pressure
reveling temp 774.93k
compresaablity factor is 1 and Kb, Kc are 1 resp, and is concated to flare header .
My query is in inlet line sizing i can take releving pressure P1 ?and what temp has to take inlet line sizing condition .And in outlet line sizing calculation what is pressure and temp i have to consider . i gone through Api 520 and Api 521 for outline sizing but i'm able to understand it properly . so plz help to find out the solution.
Thank u .
