My question is some what heat transfer related. Please forgive me if you think this is not a good fit for this forum.
I have an existing shell tube exchanger, using 90 psig steam to heat up potable water (used for safety shower for winter time). Steam flow is controlled by a 1" control valve to maintain potable water to ~80F.
We are planning to replace this shell tube exchanger with a double wall plate frame exchanger. But this type exchanger has a temperature limit ~350F, thus I can not use 90 psig steam. I found a lower temperature medium - condensate with temperature 240F.
My question to the peer group is , can I move the control valve from steam line to condensate line? since the cold side is the same stream and I just switched the heating medium, it will save big money if I can keep the control valve.
Thanks.
