We hav a case where the KOD is not performing, resulting in significant liquid carryover to the flare tip. Most of the liquid falls on ground like burning oil.
1. Compared to installing a bigger KOD, replacing the flare tip would take less time (faster delivery of tip by flare vendor, compared to KOD vessel).
2. Is it possible to replace the flare tip such that it can handle higher liquid flow (say larger oil droplets of 2000 micro-meter, compared to original design of 300-600 micrometer size).
Any body dealing with such issue, pl provide inputs.
On positive side, facility is operating for long time, so the flare gas flowrate is much lower than original design flow. This may allow for replacing the flare tip of diff spec.
Thanks.
Apurv.
