What are some preferred vendors for conductive PFA or PTFE hose with a silicone outer cover in small sizes (1/2" and 1")? Swagelok's coreflex is excellent, but I was wondering if there are some less expensive options. I'd prefer smooth bore hose with a low minimum bend radius. I've found one or two alternatives to coreflex but the bend radius is not as tight. Pressure rating can be low (even 100 psi). PFA or PTFE is a must due to the wide range of chemicals processed (specialty chemical).
Ptfe Lined Hoses
Started by fseipel, Sep 18 2013 05:30 PM
No replies to this topic
Posted 18 September 2013 - 05:30 PM
Does Ptfe Based Grease React With Anti-Corrosion Agents And Dissolve IStarted by Guest_Sam1999_* , 29 Apr 2021 |
Line Sizing Criteria - High Temperature, Low Pressure Refractory LinedStarted by Guest_modgasman_* , 03 Sep 2019 |
Teflon (Ptfe) VesselStarted by Guest_SP500_* , 11 Feb 2017 |
Glass Lined Reactor LifeStarted by Guest_modianurag_* , 21 Dec 2016 |
Heating Time In Glass Lined ReactorStarted by Guest_modianurag_* , 11 Sep 2016 |
