Hi
i need to size the centrifugal pump minimum flow line control valve
Liquid pumped out form External floating roof tank through centrifugal pump and minimum reciculation line of the centrifugal pump connected back to the bottom of the floating roof tank in this minimum recirculation line have FV flow valve i need to size this control valve
Note : i dont have pump vendor information
Downstream of the control valve which pressure i have to consider
Upstream of the control valve i consider pump discharge pressure
Minimu flow considered as 30% of the pump rated flowrate
