We have a flowmeter (0-1000 L/hr scale) installed whose spec. sheet mentions a guaranteed accuracy of 2% of the Full Scale Deflection. (for flows greater than 100 L/hr)
The unit also has an integrated electronic totalizer. The debate among some of us is whether this implies (by logic or convention) that the totalizer too would be 2% accurate? Or does the totalized flow accuracy have to be independently mentioned by the vendor. (I haven't seen them mention it)
e.g. if after 20 minutes of flow the totalizer reads 150 Litres, can it be assumed that (in a legitimately performing instrument) the true metered quantity would be 150 +/- 6.6 Litres? (6.6 and not 3 because the reference used is FSD not actual reading)
Also, in general cases, where not mentioned explicitly would totalized accuracy be better or worse than the dial accuracy or can it be either way.
Comments?
