We are somewhat confused regarding on the difference on process of precipitation from the process of crystallization in industrial companies. Can you please help us?
Posted 28 October 2013 - 02:28 AM
Posted 15 November 2013 - 11:38 PM
Precipitation means converting the dissolved material to suspended material. Crystallization is the same thing with a goal of having specific particle size in precipitated material.
Posted 16 November 2013 - 12:43 AM
Normally for precipitation a precipitating reagent is added. Often it is a chemical reaction. Sometimes a physical agglomeration process. The precipitate may not be necessarily crystalline but can be.
Crystallization usually employs a solubility effect. By cooling or evaporating off solvent a solute is forced to come out of solution. It is usually a relatively slow process if crystal morphology / size is important.
Hydrated And Anhydrous Form CrystallizationStarted by Guest_Izaaz_* , 01 Sep 2023 |
Crystallization Of Nacl With Seed CrystalsStarted by Guest_jordan1111_* , 23 Mar 2023 |
Modeling Fractionation & CrystallizationStarted by Guest_waheed2020_* , 04 Oct 2022 |
Crystallization ProcessStarted by Guest_leon_neo_* , 20 Feb 2021 |
Prevention Of Secondary Nucleation Crystallization In Plug Flow ReactoStarted by Guest_Jeannot_C_* , 16 Dec 2020 |
