Location For Ro, Before Or After Flow Control Valves
Posted 31 October 2013 - 02:50 PM
Posted 31 October 2013 - 02:56 PM
HnAw,
Orifice plate (not RO) as a flow element for flow measurement should be located before flow control valve...
Posted 31 October 2013 - 03:00 PM
HnAw,
i want to use RO not for measure, its for pressure drop , i m looking cavitation index in the flow control valve is around 1.3
Posted 31 October 2013 - 04:10 PM
Hi. I don't get it. Why do you want to use a RO if you know that the discharge is atmospheric??? As Fallah said, you should use a flow element in that case.
Posted 31 October 2013 - 05:35 PM
this is hte model , fullfill pipe ( not a channel) service water for tailing dilution (mining) wiht controlled flow
Posted 01 November 2013 - 01:31 AM Best Answer
HnAw,
The attached model cannot be downloaded, your english cannot clarify your query well...
By the way due to gravity flow and atmospheric pressure at downstream, appears it is better the RO to be at control valve's downstream...because if it would be at upstream might cause the tailpipe not to be filled with water in its full cross section... then the control valve cannot do the job well...
Posted 01 November 2013 - 12:20 PM
HnAw,
Thank you very much Fallah
![]() Flow Through Normally No Flow LineStarted by Guest_iippure_* , 08 Apr 2025 |
Smr Reformer Flue Gas FlowStarted by Guest_kaidlut_* , 14 Feb 2025 |
