I am new in the industry and need some advice:
My company is running an offshore production which oil and ascociated gas are treated and compressed by a leased facility, operated by others.
During start up and ramping up, we estimate that for the first 3 month we only have a limited amount of ascociated gas.
Gas Compressor type : Centrifugal, 3 stages (2 trainx 50% capacity)
Design gas compression capacity : Total feed gas of 70 MMscfd, 35 MMscfd design capacity/train
Required pressure of gas export header is 100 barg max
The plan was to run one of the compressor train once we see enough gas to run it with full recycle, matching the design capacity:
Feed Gas : 19 MMscfd with recylce of 16 MMscfd (19 +16) ~ 35 MMscfd
Our contractor seems reluctant and said that the operations will be troublesome with lots of process trips because of high temperature and vibration on our first meeting explaining this plan. I want to be fully equiped with understanding of the problem first before meeting with them again.
The thing is we have a recyle line from the last stage discharge back to the 1st stage, upstream the cooler and scrubber that technicaly adequate to reduce the temperature back to the 1st stage feed gas temperature. Everything seems fine to me, i do not understand where their concern comes. Did I missed something?
Thanks,
Mada Analaum
