I have seen that high flow high head pumps generally have a high NPSH requirement and generally
are given a bosster pump along with.
Could you please explain the concept and reason behind this
thanks
Posted 14 November 2013 - 08:45 AM
thanks
Posted 14 November 2013 - 12:05 PM
PYG,
It is supposed your query relates to centrifugal pumps...
NPSHR value mostly depends on flow rather than pump head and becomes higher as flow increases. In fact, this means more pressure head would be required at the pump suction for high flows than low ones. A booster pump would be used to compensate shortage of NPSHA which cannot be simply provided in some high flow cases...
Seeking Feedback On My Process Flow Diagram. Biogas Steam Reforming ToStarted by Guest_Jacobaum_* , 27 Oct 2025 |
Two-Phase Fluid Flow Through An OrificeStarted by Guest_frwvelandria_* , 13 Oct 2025 |
Vacuum PumpStarted by Guest_R.t_* , 19 Sep 2025 |
Wet Scrubber Design For Low Flow Rate Of GasStarted by Guest_SIVAMOORTHY_* , 17 Apr 2018 |
