Drying Cl2 Gas Through A Packed Column
7 replies to this topic
#1 Pingue2008
Pingue2008
  • 136 posts
Posted 16 January 2014 - 03:04 PM
Dear members,
I am trying to dry chlorine before sending it to the compressor. I am trying to simulate a packed column that will absorb most if not all the water vapor from the chlorine stream. I am using H2SO4 as solvent. I used a Radfrac column from aspen plus but I can't get to converge. The error message has some to do with stages (I said that the tower had 2 stages because I had to enter something) . Any help in simulating a packed tower in Aspen Plus will really be appreciated. I was also wondering if I was using the right unit operation, but I looked around could not find better.
Thank you,
  • 6,942 posts
Posted 16 January 2014 - 11:33 PM
http://krebs-swiss.com/cl2drgpi.htm
Pingue ,
Hope this helps for the unit operation .
#3 Pingue2008
Pingue2008
  • 136 posts
Posted 17 January 2014 - 06:59 AM
Breizh ,
What I am trying to do is simulate that process in Aspen Plus. I was given the material balance. I've been to the link you posted. It does not address my problem.
Thank you,
#4 thorium90
thorium90
  • 1,073 posts
Posted 17 January 2014 - 09:41 AM
You received an error message in aspen plus which you do not understand. Perhaps you can provide more info on your problem. At present, no one knows your problem. All that is known is what you were trying to do.
#5 Pingue2008
Pingue2008
  • 136 posts
Posted 17 January 2014 - 10:27 AM
Thorium,
I don't know how else to explain. The attachment may be helful. I will upload the aspen file later.
Thank you,
#6 thorium90
thorium90
  • 1,073 posts
Posted 17 January 2014 - 10:49 AM
Perhaps you can zip up and post your aspen plus file here. Or perhaps a screenshot of the error messages you receive along with some screens of your simulation etc
#7 Pingue2008
Pingue2008
  • 136 posts
Posted 17 January 2014 - 12:16 PM
Dear,
I got it to run with two stage attached is pdf of the simulation but i don't like the results. it not really doing i want.
I will keep on working on it. meanwhile if you think of anything that i am doing wrong let me know.
Thank you,
#8 breizh
  • 6,942 posts
Posted 18 January 2014 - 12:40 AM
Pingue 2008 ,
Wet Cl2 should be introduced at the bottom of the column and H2SO4 sol at the top , at least for clarity!
Edited by breizh, 18 January 2014 - 12:41 AM.
