Dear all ,
I have two questions based on some connections in cooling water supply and return line in the compressor inter coolers.
1. Why globe valves are used in return line and gate in supply.
One idea is to throttle. I can easily throttle the globe valve it was present in supply also.In that case i would have put gate valve in return....So the question is why specifically globe valve is put in return line of cooling water.
2. There is sometimes a jump over sort of connection from upstream of globe valve in return line to upstream of gate valve in supply line. What is the purpose of that line. Kindly put your valuable reasons for these to questions..
Attached is the schematic for reference.
Thanking you,
Supriyo Mukherjee
