Connections
Posted Today, 03:53 AM
Posted Today, 06:10 AM
I have no specific experience, but your valve and piping specifications ("pipe spec") for this service and pressure and temperature range should guide you in this decision.
Hopefully someone with specific experience will reply.
I do know that screwed connections in DN15 to DN25 are usually given great latitude at equipment and instrument connections because screwed connections are so common in these small sizes. Specific PTFE tape, pipe thread dopes, and even seal welding where feasible are usually optional. I would not want to seal weld a screwed PSV/TRV though.
Posted Today, 07:32 AM
Top Foam Pourer Line- Reducer ConnectionsStarted by Guest_RAFAELDAVE_0752_* , 03 Sep 2025 |
Nozzle Loads On Thermal Oxidizer Inlet ConnectionsStarted by Guest_unoerudite_* , 11 Aug 2016 |
One Stream Two Connections In Hysys/unisimStarted by Guest_J_Leo_* , 30 Mar 2016 |
Use Of Flexible Connections In Hydrocarbon Systems (Oil, Gas)Started by Guest_Sherif Morsi_* , 08 Mar 2016 |
Compressor Intercooler.. Water Line ConnectionsStarted by Guest_Supriyo Mukherjee_* , 17 Jan 2014 |
