Equilibrium
#1 ss3
ss3
  • 15 posts
Posted 22 March 2006 - 12:28 PM
Hiya,
My qn is: 2 connected cylinders with the same gas. One at a pressure of 3bar, the other 2bar. When mixed together to reach equilibrium, what are the final pressures in both? Is it 2.5 bar each?
#2 aliadnan
aliadnan
  • 88 posts
Posted 23 March 2006 - 01:17 AM
Hi SS3
Please check out the following link. I hope you will get a better understanding of this topic after reading
http://www.cheresour...wtopic=1604&hl= <------ Click Here
#3 ss3
ss3
  • 15 posts
Posted 23 March 2006 - 05:15 AM
Thanks for ur help..I understand the pressure bit much better now.
In the same question, I forgot to mention that the process is at constant volume. Referring to the attached diagram, does that mean when the stops are removed & all oscillations have ceased that the piston would return to its initial length, L=10cm since volume is constant?
Thanks...
#4 ss3
ss3
  • 15 posts
Posted 23 March 2006 - 10:59 AM
Apologies..
The process is NOT at constant volume but reversible adiabatic. So I take it the lengths WILL now change & the piston would move to the right. If both cylinders are at the same temp. How do I find the final temp if it's an ideal gas?
