Co2 Capture Using Amines
Posted 24 February 2014 - 04:13 PM
Posted 26 February 2014 - 10:43 AM
It's very easy to come up with an initial amine flowrate based on stoichiometry and gas flow.
kmol/hr of CO2 / desired loading (molCO2/molamine) = kmol of amine/hr
Then you need to divide by the fraction of amine in solution to get your kmol/hr of solution.
Then convert to whatever units you need.
However, this is just the starting point. That assumes the reaction reaches equilibrium, which in most cases it does not. You will need ProMax to calculate how far from equilibrium the reaction actually proceeds to. I don't know if ProMax has the amine you have, but I suggest you contact BRE to find out. They pretty much have the top expertise on amine sweetening, which I suppose is why their simulator is the only one that can do calculations like this.
Posted 31 March 2014 - 02:18 PM
Thanks a lot....Happy new month...
![]() Carbon Capture Absorber SimulationStarted by Guest_raisoturu_* , 21 May 2024 |
Steam Requirement For Mea Reboiler - Co2 Capture From Flue GasesStarted by Guest_liquidcarbonic_* , 25 Sep 2023 |
Best Practices For Extraction Of Amines From Wood TarStarted by Guest_quantum31_* , 19 Jun 2023 |
Co2 Capture QuestionStarted by Guest_panoska_* , 04 Mar 2023 |
Cryogenic Capture Of Co2 From Lng By AirStarted by Guest_tarang.suthar_* , 01 Mar 2023 |
