hi
I am sizing a control valve for non-chocked, turbulent flow, i have calculated Cv , but how to select the Valve size against this Cv.
Posted 10 March 2014 - 12:23 PM
hi
Posted 10 March 2014 - 05:09 PM
Arslanakram.np
Normally, for the better control, the size of the control valve selected is either smaller than the line size or equal to the line size.
However, as a process engineer, your job is to calculate the Cv based on three conditions 1) Maximum flow rate 2) Normal flow rate 3) Minimum flow rate and then give all the relevant information to the valve supplier.
Valve supplier will then feed all these data into the valve sizing software and/or check against the tables/catalogues and suggest you the valve size. Again, there are various types of control you can select i.e. linear, proportional etc depending on applications.
Hope this helps.
KS
Posted 10 March 2014 - 10:57 PM
Hi Arslan,
you have valve Cv, then you can select the control valve size (as the preliminary size) based on Cv vs NPS/DN table (Fisher, Samson, or other CV vendor).
Royen
Posted 11 March 2014 - 02:28 PM
Thanks , it is really helpful
Posted 11 March 2014 - 09:51 PM
A process enginner needs to select carefully the amount of pressure drop required across the control valve for proper controllability. You can go through Spirax-Sarco resources to get the whole picture. Good luck.
http://www.spiraxsar...ter-systems.asp
Automatic Choke ValveStarted by Guest_Mudassssir011_* , 22 Jul 2025 |
![]() Guidance On Sizing Jacketed Pipe For Glycerine CoolingStarted by Guest_Kentucky08_* , 28 Jun 2025 |
