Hydrochloric Acid Heat Exchanger
hcl hx heat exchange tubing for hcl hydrochloric acid
#1 Subject_Name_Here
Subject_Name_Here
  • 30 posts
Posted 11 March 2014 - 02:50 PM
Hi everyone,
I am looking to heat a product stream that contains less than 1% HCl (max temperature at 200 F). I was recommened 316 ss, but over the course of one month 3.7% HCl caused severe leaking in 316 ball valves. Stainless is out!
Can anyone suggest a compatible tube material for my application?
Thanks in advance!
  • 6,939 posts
Posted 11 March 2014 - 07:05 PM   Best Answer
Consider using graphite for this type of application !
Google : Graphite HX :https://www.google.c... heat exchanger
#3 Subject_Name_Here
Subject_Name_Here
  • 30 posts
Posted 11 March 2014 - 09:57 PM
Thank you!
#4 RaoulM
RaoulM
Posted 24 March 2014 - 11:56 PM
I have not had experience with graphite exchangers, but you could also consider titanium as a material of construction. Whilst the material is expensive, if you opt for a plate/frame heat exchanger, you may find that the costs are economically feasible. What material are you using for the pipes?
Raoul
