Insulation Thickness Determination
#1 ulka_19
ulka_19
  • 32 posts
Posted 17 April 2014 - 07:14 AM
Hello Everyone!!
I need to determine the insulation thickness for my storage tank which contains Bitumen at 150 C. There is a bottom heating coil arrangement given inside the tank for heating Bitumen. However the thickness of tank is not constant. At bottom, shell thickness is 14 mm and as it goes up it get reduced to 6 mm. I also referred old posts regarding the same topic and found this information from Ankur Sir very useful "Download the insulation and pipe heat loss calculation software from the North American Insulation Manufacturer's Association (NAIMA) website"
I downloaded this software and calculated for Tank Shell- horizontal. Although I got my calculation report but I have following doubts:
1. Does it take care of varying shell thickness?
2. I am not able to find my insulation material rockwool in the given drop down list, how should i relate or select the material from that list only?
3. What Efficiency can be considered as optimum to decide the minimum required thickness?
#2 AlertO
AlertO
  • 194 posts
Posted 17 April 2014 - 08:42 PM
hi ulka
see my answer below
1. the simplified calculation is fine. you may use the thin wall to calculate your heat loss giving the maximum insulation thickness.
2. you may compare the thermal conductivity of the rock wool with the material in the list. similar condutivity material can be used in your calculation.
3. optimum insulation thickness is carried out from comparing to the steam consumption.
Hope this may help you
#3 breizh
  • 6,718 posts
Posted 17 April 2014 - 11:27 PM
Hi Ulka ,
Probably good to read.
Insulation materials table :
http://www.engineeri...vity-d_429.html
Edited by breizh, 18 April 2014 - 01:17 AM.
#4 ulka_19
ulka_19
  • 32 posts
Posted 17 April 2014 - 11:28 PM
Thanks.
