Hey guys
I've noticed that on FLARENET 7.3 no matter how high you set the flowrate, the pressure at the flare tip inlet is atmospheric pressure. (mach 1 flow still shows atmospheric pressure at tip)
If the required velocity through the tailpipe is above mach 1 (of the fluid), there will be a pressure build up such that the volume decreases and the required mass flow can flow through the tailpipe. The pressure calculated at the tip can be used for reaction force calculations.
FLARENET 7.2 gave you the pressure at the flare tip when the flow was choked which you could use for reaction force calculations.
Anyone else having this issue 7.3?
cheers
