Gents:
We are studying whether it is possible to reduce design pressure for glycol dehydration from original design in order to increase the plant capacity as existing glycol dehydration is limited through 4 x 12 reciprocating compressors .
Capacity: 120 MMscfd @ 900 PSI and 110 F
As I stated current glycol dehydration running at low flow 48 MMscfd therefore, suggestion is worth to study it.
Proposed pressure is 320 psi and flow 100 MMscfd without any change in gas composition and feed gas temperature.
My question is if glycol dehydration pressure reduce from 900 psi to 320 psi is such of turndown in the pressure would have any impact on the capacity and dewpoint ? of course , there will be additional requirement on glycol regeneration skid such as pump, heat exchanger etc.
I will appreciate your support and help .
