Hello ,
Furnace is designed for natural gas fuel of net calorific value ~9000 kcal / Nm3.Furnace contains several numbers of burners (say 125 ).Later on, There is arranged an recovery of low calorific fuel (~ 1200 kcal /Nm3 NCV) from the process(~10% recovery equivalent NG).It is also connected to consume as a fuel alongwith NG for Furnace to establish energy conservation.
Here, My questions are
(1) Combustion of high & low heat content fuel will run the system normal?
(2) How will it affect combustion efficiency?
(3) What will happen to flame length & intensity?
(4) Will it increase or decrease combustion air requirement for fire box?
(5) These two fuel gas have different wobbe index. How does it affect flame characteristics in actual operation?
(6) Will Secondary fuel get combusted fully in presence of NG operating at certain burner pressure?
Thanks in advance.
DDR
Reformer Furnace
Started by drdave, Apr 02 2006 12:15 PM
Smr Reformer Flue Gas FlowStarted by Guest_kaidlut_* , 14 Feb 2025 |
Calculation Of Approach To Equilibrium Of Primary Reformer CatalystStarted by Guest_muthukmaar_* , 05 Jul 2019 |
Ch4 Reformer Firing Control SchemeStarted by Guest_Divid Kelin_* , 11 Jan 2023 |
Hydrogen Fired Steam Cracking FurnaceStarted by Guest_panoska_* , 17 May 2022 |
Steam Methane Reformer In Production Of Methanol From Natural GasStarted by Guest_adam123collings_* , 01 Mar 2022 |
