I have a thermal relief valve on an LPG line. The tailpipe is routed to the flare.
It seems very conservative to check outlet line sizing based on the rated flow of the thermal relief valve as the pressure will drop instantaneously when the RV opens.
Maybe considering built-up back pressure with required relief rate would be better to use. However this still seems unrealistic as with thermal relief the relieving fluid is probably not even going to reach the flare header before the pressure has dropped and RV closed.
What's the normal approach for thermal relief outlet line sizing?
cheers
